snapped bolt...
Old Sep 24, 2007 | 11:12 PM
MustangEater82's Avatar
snapped bolt...
what ideas are out there... snapped an intake manifold bolt on a 3.8L
its nearly flush with the block. Generally I am a lucky *******, and I pull the part and can get the rest of the bolt out with vice grips?
reverse drill bit?
buy a new motor and say **** my cursed piece of **** 3.8L?
Old Sep 24, 2007 | 11:31 PM
qa767's Avatar
There are several options. Soak the bolt with a penetrant, then using a pointed punch or chisel held at an angle. Hit the bolt in a counterclockwise direction. If there is enough material sticking out, cut a slot into the bolt and use a straight slot screwdriver to back it out. Or use an EZ-Out. Good luck.
Old Sep 25, 2007 | 08:51 AM
Lunch Box's Avatar
You can get tools/extractors for removing broken bolts, if I were you I'd pony up and get one or a small set
I've broken more than a few bolts off in various pieces of equipment myself
Old Sep 25, 2007 | 11:16 AM
OMGWTFBBQ's Avatar
Home depot/Lowe's carry a small bolt drill.
it;s got a side to bore a hole, and then a tap/pull out side.
It worked on some home screws.
Old Sep 25, 2007 | 08:33 PM
Bayer-Z28's Avatar
Left handed drill bit or an easy out... Or both.. If the LH DB doesn't get it out then you'll have a hole for the easy out..
Old Sep 25, 2007 | 09:26 PM
94Camaro_Z_28's Avatar
I'd use an easy out myself.....thats how I got the broken head bolt out of my LT1.
Old Sep 26, 2007 | 12:04 AM
woot... drill slipped tip snapped not sure where it went...
probably in the motor...
BTW the bolt is under the cowl, so its really hard to get to.
**** it, think I might just go with a new motor. Thing had a knock before I started this bull**** anyways...
PopoFormula
Oct 12, 2015 04:19 PM
Aaront810
Sep 11, 2015 11:24 AM
sup_sales
Jun 25, 2015 11:10 AM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
Robbie
Feb 20, 2003 08:55 PM
