Shift light question
Old Oct 13, 2004 | 09:20 PM
KamaroL98's Avatar
Im getting a turbo400 and want a shift light. I dont want a big tachometer. Just a small light to mount discreetly on my dash. Someone told me i cant use one of these "unless" i have an MSD ignition!? If you know otherwise, how do i hook one up?
Old Oct 13, 2004 | 10:58 PM
Bud M's Avatar
Re: Shift light question
You can hook up a shift light without an MSD box. Mine is wired into the wiring at the coil for the signal. On a 93 the wire is pink/black, may be different color on later years.
Old Oct 14, 2004 | 07:16 AM
teke184's Avatar
if i remember correctly, white wire, pin 35 on the red connector on the ECM under the hood. that's the tach output wire
splice into that and just connect the power and ground.
and most lights will need to be set to "4 cylinder mode" due to the design of the LS1 ignition.
Old Oct 14, 2004 | 07:32 AM
WayneE's Avatar
As others mentioned, just hook it up to the PCM tach output. I run a Raptor light on my Z06 (and Hayabusa) and they work very well.
blac94Z
Jan 12, 2015 05:44 PM
cmdeshon
Dec 27, 2014 10:06 AM
Jul 4, 2005 05:00 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
Krab
Aug 5, 2002 12:08 AM
