serpentine belt tension
Old Sep 28, 2011 | 03:40 PM
CAMBURT's Avatar
Question serpentine belt tension
does anyone know what the belt tension should be on a 94 camaro 3.4? and also how to replace the belt tensioner? could a bad tensioner cause the car to run hot at idle but once moving the car runs fine. any help
would be appreciated.
Old Sep 28, 2011 | 03:56 PM
jmd's Avatar
jmd
Re: serpentine belt tension
Naah; the water pump runs directly off the belt; any slippage you'd hear it.
idle heating up points to fans not running whereas once moving you have airflow.
Old Sep 28, 2011 | 04:28 PM
BC2002SS's Avatar
if you look at the tensioner there will be range marks and the arrow should be in-between them
Old Sep 29, 2011 | 01:37 PM
rv93's Avatar
that cant be the cause of the problem. sounds like your fans arent coming on. check that first. if the water pump wasnt spinning as fast as it should, youd be running hot regardless. perhaps even more while driving.
Old Sep 29, 2011 | 06:07 PM
CAMBURT's Avatar
does anyone know how to replace the belt tensioner?
Old Sep 29, 2011 | 08:23 PM
rv93's Avatar
i assume its the same as most cars. find it, and there should be 2 bolts holding the base down on the block or head. take those out, and it should come right off. make sure the belt is off before you do this
95blkss
Sep 22, 2015 03:18 PM
rideordie
Sep 7, 2015 08:22 AM
4586
Aug 18, 2015 07:08 AM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
