running lights stay on after engine change
Old Sep 18, 2013 | 03:45 AM
LT4orbust's Avatar
Any ideas why just the front running lights are staying on,1997 WS6. Just finished the 383 install from the bottom , new fuel pump also. I looked for open grounds and pinched wires. I didn't drive it yet ,but it sounds unbelievable,instant responce!
Also it seems to want to keep running for about a sencond or two after turning the key off...??
One more thing , the o2's aren't connected yet,need extensions,....maybe feedback?
Old Sep 18, 2013 | 11:22 PM
LT4orbust's Avatar
Re: running lights stay on after engine change
are wiring diagrams somewhere on this site? i need ip and front end diagrams
Old Sep 18, 2013 | 11:43 PM
LT4orbust's Avatar
just another quick question , too late to ck it out. is there wiring down the rt side sill plate? maybe i ran a screw into the wires??
Old Sep 19, 2013 | 11:00 AM
GaryDoug's Avatar
Prominent Member
You can get the complete 96 service manual here:
http://www.mediafire.com/?40mfgeoe4ctti
Should be the same as your 97 for maybe 99% of the information
Old Sep 19, 2013 | 11:43 AM
LT4orbust's Avatar
The dam dash just burned up, a little, when i put the battery charger on it today it started smoking through the top center vent. It could have been total.!
A copper strip along the top of the tach on the pcb seems to be where the little fire started. Smoke filled the car inless than a minute while i was disconnecting the battery and ripping the bezels off, the cluster and upper panel are the only loss. The car seems to be fine now, no lights staying on,starts,runs idk, need to get a new cluster and try it
dirtybird81
10
Jan 6, 2015 09:31 PM
Jan 5, 2015 07:14 PM
Collector Car
Jan 5, 2015 10:58 AM
NorthPoleDev
Dec 31, 2014 03:20 PM
Jul 4, 2005 05:00 PM
