Running hot I think. 96 SS
Old Jun 21, 2011 | 10:36 PM
SSinister11x's Avatar
Hello all. My 96 SS six speed is running pretty hot. I have a scanner on it. The guage on the dash reads just under the redline mark and the scanner tool reads 234 before the fans kick on and cool it down to about 219. Then it returns to 234 and so on. This is when the car is just sitting in the garage. About 75 degrees outside. Is this cause for worry? Thanx 4 any help in advance.
Old Jun 21, 2011 | 11:54 PM
8cylinders>4's Avatar
Re: Running hot I think. 96 SS
it sounds like your fans aren't working when they are supposed to be commanded on at low speed at 226 degrees, while the high speed fans are supposed to kick on at 235 degrees
your car should have a three fan relays, one is used to achieve slow setting, and both the other ones are used for the high setting, the relay used to control your low setting may not be working.
Can you conclude the fans are working on the slow setting, coming on at 226 degrees? you'll have to physically check since you rarely hear the fans when they're turning slow. If that checks out, another common issue with these cars is debris getting stuck between the radiator and A/C condenser.
Old Jun 23, 2011 | 02:55 AM
Yes, it does seem like the low speed fan is not bein triggered. The High speed kicks in at 235. I replaced the two relays that work the high settings. Now i'll go check that third one. Thank u. We'll see how it goes.
calaban
May 18, 2020 06:43 PM
Collector Car
Dec 17, 2014 01:12 PM
jayblev95
Dec 1, 2014 06:55 AM
CLEAR
Aug 30, 2002 07:49 PM
