Removing ASR traction control
Old Jun 7, 2005 | 11:07 AM
96PTKZ28's Avatar
Question Removing ASR traction control
I am wondering if it is possible to get rid of the ASR traction control on a 96 Z28. I would like to retain the ABS if possible. THe reason I want to get rid of it ( besides the fact that its worthless in AZ) is that I am upgrading to the LTCC coil per cylinder ignition and going with a PTK turbo setup. I want more room and I figure there has to be a way to ditch this waste of space. ANy suggestions would be appreciated.
-Beau
Old Jun 7, 2005 | 12:05 PM
teke184's Avatar
Re: Removing ASR traction control
i think you'll need some new brake lines and a throttle cable.
do a search in the "forced induction" section, since it's required to run most SC setups.
Old Jun 12, 2005 | 09:15 AM
96PTKZ28's Avatar
So there isnt anyone that has removed their traction control on this board?? Teke 184, thanks for the ideas. Im thinking they might get pissed if I post this in FI. Might think its off topic. Thanks again.
Old Jun 12, 2005 | 09:32 AM
Red 97T/A A4's Avatar
There was a guy on here who removed his without having to replumb the brakes. I think his name is trax. Best I can remember, he swapped out his brake control module with one from a non tcs car and switched the throttle and cruise cables. Do a search on his name and you should find the info.
Rod Bender
Nov 7, 2023 02:30 PM
dluna333
Parts Wanted
Mar 6, 2015 07:11 AM
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
Jul 4, 2005 05:00 PM
