rear window defroster problem
Old Apr 20, 2009 | 02:37 PM
diabeticfirebird's Avatar
Rear window defroster button lights up first time, after a few minutes windows start to defrost then just stop. i push the button again and all i here is the button clickno light and window will not finish defrosting. any ideas on wat i need to fix?
Old Apr 20, 2009 | 06:27 PM
moparman's Avatar
Replace the 30 amp circuit breaker with a 30 amp FUSE.
Old Apr 20, 2009 | 07:53 PM
Hal Fisher's Avatar
If I remember right the rear defroster is on a timer. It only stays on for a while. Once it shuts off you also can't move your seat (must be on the same circuit). Maybe it gets too cold in your area to defrost before it shuts off?
Hal
Old Apr 21, 2009 | 02:05 PM
it works for awhile then shuts off and wont come back on, im gonna check the fuse tonight.
Old Apr 21, 2009 | 02:27 PM
Hal Fisher's Avatar
Did you bother to read my post?
Hal
Old Apr 21, 2009 | 06:41 PM
It is on a circuit breaker (yes, the seat is on the same breaker). If you do what moparman said, it usually takes care of it.
Old Apr 24, 2009 | 09:12 AM
thankyou fixed
Old Jun 13, 2009 | 03:08 PM
just wanted too update this... bad advice on the 30 amp fuse come too find out one day it had melted all the area surrounding the fuse couldve been bad had i not looked. so just wanted to say dont do this get the original fuse.
Old Jun 13, 2009 | 05:20 PM
All situations are not equal. Mine has had a fuse for 8 years or more. I don't really use mine much, though. You can tell that the fuse does get hot.
Best idea would be to have the circuit and grid repaired if it does not work properly with the original circuit breaker.
Old Jun 15, 2009 | 09:42 PM
ya mine melted and i wasn't even using it.. its hot out..lol but itll get fixed so im not stressin anymore
Old Jun 15, 2009 | 10:45 PM
If the fuse melted and you weren't even using it, then that would be a problem that needs repair.
redleader
Parts Wanted
Nov 13, 2016 02:57 PM
dale3in98
Feb 14, 2015 12:18 PM
Fatdog2
Jan 24, 2015 12:08 AM
Jazsun
Dec 29, 2014 12:14 PM
