Rear window defrost
Rear window defrost
Not too long ago, my rear window defroster stopped working on my 97 Z-28. I checked the fuse and it's fine, I located it down to the switch itself. I pulled the panel apart to find out that there's a circuit card inside and maybe that is the problem. Do I need to replace the whole panel, A/C controls and all, or can I just replace the card inside?
Re: Rear window defrost
breaker/fuse, yeah, that's what I meant...but it works because I swapped it with the one under it and there was no change. Also, it's the same breaker that the power seat is ran through, and the seat works fine.
kizz
Jul 6, 2002 11:03 AM
