Rear end cover
Old Aug 9, 2004 | 08:16 PM
ZyberMunster's Avatar
Rear end cover
Sorry for the "dumb" question but I bought a MAC rear end cover and since it's used didn't bring no instructions...
How much do I torque the two allen bolts that support the caps??
I assume you bolt and torque the cover's 10 bolts and then tighten the "cap bolts" and finally lock them with the nuts.
Anyone that's installed one before care to shoot me some info?? Much appreciated!!
Laterzzz...
Old Aug 9, 2004 | 09:12 PM
n2ceptor's Avatar
Re: Rear end cover
MIne are set a 8-10 flbs
Old Aug 9, 2004 | 09:18 PM
Josh'95Z28conv's Avatar
Re: Rear end cover
The instructions in my LG cover said to tighten them 5 ft/lbs
PatriotTA's Avatar
Re: Rear end cover
The instructions that came with my TA Performance cover says to torque the cover bolts to 25 ft-lb, then tighten the preload studs with your hand until they make contact. Then tighten them NO MORE than 5 ft-lbs. Then use the nuts to lock them in place. Any overtightening of the preload studs will warp the bearing caps.
Old Aug 10, 2004 | 08:01 AM
Re: Rear end cover
Guys, you're the best!!
Thanks a bunch
Laterzzz...
Old Aug 10, 2004 | 01:38 PM
Hyperspeed97z28's Avatar
Re: Rear end cover
http://www.installuniversity.com/
They have an install guide for the T/A girdle. Mac is the same thing ...
Old Aug 10, 2004 | 10:16 PM
Bud M's Avatar
Re: Rear end cover
If you haven't installed it yet you might want to wrap a little teflon tape around the drain plug. Mine leaks a bit.
CARiD
Feb 9, 2015 09:35 AM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
