Rear Axle Bump Stops
Old Aug 11, 2022 | 09:18 AM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
Thumbs up Rear Axle Bump Stops
Well after 21 years Sara (2001 Z28) bump stops are toast. I am thinking of replacing them with the polyurathane stops, and would like your opinions on why to use or not to use them.
Thanks in advance.
Old Aug 13, 2022 | 02:54 PM
BandDirector Blk98ZM6's Avatar
Re: Rear Axle Bump Stops
Just get the 18271.07 axle snubbers made for a Jeep but fit the F-Body. They're rubber and cheap ($5-$6 each). I think the polyurethane will make for a harsher ride vs. rubber. I run the rubber ones on mine and they work great!
Old Aug 13, 2022 | 04:13 PM
Sam Strano tested poly, GM foam, and rubber. He comments on stiffness. Seems to me they really only come into play with extreme vertical compression, or severe body roll. I doubt they play much part in non-extreme driving, unless severely overloading the rear seats and hatch area. But that's just a guess. After 27 years my stock GM foam was still intact, so I doubt they ever came into play with the car's fairly extreme drag track use.
The study only shows up when you see the “Announcements” when you first open his site, or there's a place to pull up the Announcements on the blue band at the top of the page.
http://www.stranoparts.com/
Old Aug 17, 2022 | 08:26 AM
SteveC's Avatar
Thank you all for the input, I am going to go with the poly mounts, with the extended jounces that SLP uses. My vehicle is stock height with 18" wheels.
pearlpurple
Jul 7, 2007 06:44 PM
gamecockfan04
Mar 21, 2005 03:23 PM
96camaroz28lt4
Mar 12, 2005 11:59 AM
RobbyRob
Dec 1, 2004 03:54 PM
Red_94Formula
Parts Wanted
Jul 23, 2004 01:53 PM
