Random air bag light
Old Mar 14, 2009 | 08:50 PM
kefkafloyd's Avatar
I've been having this problem on and off lately with my 97 bird. The air bag light will go on and off occasionally. Start it up sometimes, it'll be on. Start it up others, it'll be off. I've even seen it turn on and off once or twice while I was driving.
This sounds suspiciously like a ground fault to me. I searched the forums and saw a post recommending to clean and tighten the ground next to the driver's side strut tower (right behind the airbox) but it didn't seem to solve the issue. The fuse is fine, swapped it with a known good one and it still does it.
Is it possible that I didn't clean the ground correclty? I took it off, cleaned the connector with a wire brush and reconnected it. Is there something else I should look at?
Note that I have not spun the steering column while it was disconnected, nor have I been in an accident that deployed it.
Old Mar 15, 2009 | 02:30 AM
yournamehere's Avatar
The air bag light on my '96 Z28 is on at all times, and I have cleaned the ground terminal connections to no avail. Bummer. If you ever do figure it out post the results.
dale3in98
Feb 14, 2015 12:18 PM
rwferguson43026
Feb 6, 2015 10:06 AM
Airplanedoc
Feb 1, 2015 07:14 PM
squarehead
Jan 15, 2015 07:02 PM
Jul 4, 2005 05:00 PM
