ran out of blinker fluid :(
Old Jun 29, 2004 | 09:07 AM
anasazi's Avatar
for a long time my blinkers have both been slow, so i figured they were low on blinker fluid, but this morning my right blinker finally kicked the bucket and says lit.
where is this little blinker module and how much is it to replace? i might as well do both if they're cheap because they were both slow. what part# are they?
Old Jun 29, 2004 | 11:13 AM
HBHRacing's Avatar
what actaualy happened? does one side just stay lit and not flash or what?
Old Jun 29, 2004 | 11:25 AM
falchulk's Avatar
probably just a blown bulb.
Old Jun 29, 2004 | 11:37 AM
anasazi's Avatar
the left turn signal still flashes like normal, but the right turn signal stays lit and doesn't flash.
Old Jun 29, 2004 | 11:49 AM
HBHRacing's Avatar
alright then. check your bulbs on that side. you will find one of them burt or making bad contact
Old Jun 29, 2004 | 12:01 PM
valter's Avatar
Too much blinker fluid on one side just fried your bulbs...
Old Jun 29, 2004 | 12:34 PM
anasazi's Avatar
the hazards flash twice as fast as the blinkers, and the hazards still work fine.
a burnt out bulb will cause it to stick like that? i'll check that next time i go outside
Old Jun 29, 2004 | 01:18 PM
Red96Lt1's Avatar
The module you're talking about is called a flasher. I guess it supplies the blinker fluid.
Old Jun 29, 2004 | 01:28 PM
valter's Avatar
Yes, my burnt front left bulb did the same last week.
Old Jun 29, 2004 | 07:30 PM
97z28/m6's Avatar
right side went yesturday.
Old Jun 29, 2004 | 09:18 PM
viperkiller's Avatar
Originally posted by FlyBono24
It could be the muffler bearings.... if those go out it causes a chain reaction that makes your blinker fluid to leak, usually on the right side.
dude that would suck. if the muffler bearing goes out it could also damage the kanuter valve. beleive me you dont want a stuck kanuter.
Old Jun 29, 2004 | 10:22 PM
anasazi's Avatar
replaced the big bulb and its fixed, the socket looked really burned though but we're not sure if it was the dielectric greese or if it was actually scortched
however, now my right blinker flashes about twice as fast as my left blinker. the right blinker now flashes the same speed as the hazards do.
wtf???
is the other bulb on the other side on its way out now and thats what is causing my slow blinkers?
Old Jun 29, 2004 | 11:06 PM
lastze4me's Avatar
wtf???
Napa sells a 52MM Hyperdrive Motivator Blinker Extender that generally solves that problem. Make sure your Ash Tray is also not ported, the additional air flow can often cause the Blinker Fluid By pass valve to shut down completely and cause catastrophic results.
Old Jun 29, 2004 | 11:40 PM
ponykiller z28's Avatar
i had the same problem. come to find out it was the flux capacitor that was restricting blinker fluid flow...
ps, don't forget to change the winter air in your tires to summer air for a 10 + hp gain at the rear
Old Jun 30, 2004 | 12:37 AM
Robert95z's Avatar
I thought i was lost in the 12 year old twilight zone for a minute
