Radiator drainplug leak!!!
Old Dec 14, 2009 | 04:13 PM
blackblur1996z28's Avatar
I recently replaced my leaking water pump. I noticed that coolant was coming out of my drain plug on the radiator. I went and got a new one and it's still leaking out of that little drain hole. Do I have to use teflon tape or a sealant on it to stop it from leaking? Or am i screwed and have to get a new radiator? Any info is appreciated..thanks!!!
Old Dec 14, 2009 | 06:30 PM
94Z28LS1toLT1's Avatar
new radiator
id replace the radiator if i was having that issue. i never used no teflon tape or sealant. but im not exactly sure wat others think here did u make sure the plug is tight
Old Dec 14, 2009 | 06:46 PM
Plug is as tight as it will go. I don't really want to go buy another radiator. I already spent 200 bucks on the waterpump and t-stat. Is there any way to seal up that little drain hole? I know that if I need to drain it again i'll just remove the bottom rad. hose.
Old Dec 14, 2009 | 06:55 PM
RUDEDOG's Avatar
I had that problem. I just screwed a short bolt in it. No big deal. ( 1/4 inch I think) Don't tighten very tight.
Old Dec 14, 2009 | 08:37 PM
yea rudedog is right that sounds good to do
Old Dec 15, 2009 | 03:34 PM
I used teflon tape on over half the threads and cranked it down. Doesn't seem to be any coolant coming out so far.
Old Sep 20, 2011 | 01:45 PM
Brangeta's Avatar
Re: Radiator drainplug leak!!!
I'm having a problem with a leaking radiator drain plug as well. It's a brand new aluminum radiator (unknown brand as the mechanic didn't tell me) installed May 2010 and the drain plug leaked a few drops after install. I had the plug replaced by the dealership so I wouldn't have to have coolant all over my garage, but it's started leaking again.
If I unscrew it a little bit, will it leak fluid all over as I add teflon tape? And is teflon tape going to stand up to the temperature of hot coolant over time? I realize a shower head handles hot water, but I don't know how hot coolant actually gets.
Old Sep 20, 2011 | 05:00 PM
No worries with the teflon tape.
calaban
May 18, 2020 06:43 PM
pimpen1024
Aug 19, 2015 08:36 PM
Noct
Jul 14, 2015 01:18 AM
SergheiS
Jul 5, 2015 03:27 AM
