Quick answer needed!
Hey guys, does anyone know off the top of their heads how many seals on the front of the motor could be the cause of an oil leak? I know the timing cover and the water pump shaft seals but are their any others? Thanks
Re: Quick answer needed!
Thanks guys, I just got ripped off 2 weeks ago having an Opti installed. The mechanic also replaced the timing cover gasket and the water pump shaft seals. I'm assuming he screwed up one of the those. Just wanted to make sure he doesn't try and charge me for fixing them by telling me there is some other seal that is leaking up front.
