Quick AC Recharge Question
Old Aug 7, 2005 | 07:03 PM
Yoder's Avatar
Hey guys,
Now that I have the right gauges I'm getting my A/C system charged to the correct specs. It's currently 80 degrees and 80% humidity. I'm using the a/c performance chart on shoebox's website here. My range should be 24-39 and 150-245 psi. I'm currently at 27.5 and 185 and my AC is blowing at 60 to 62 degrees...not bad since it's muggy.
So am I all good for now? I went a little higher than the bottom of my range since it's well above 40% humidity out there...Should I be at the higher end of the range or doesn't it make a difference?
Thanks for your help....
Old Aug 7, 2005 | 08:28 PM
Dave89IROC's Avatar
Re: Quick AC Recharge Question
add a little more, bring the high side over 200
Old Aug 7, 2005 | 10:34 PM
HBHRacing's Avatar
Even at your temp you should be closer to 40 on the suction side and 225 to 250 on the discharge side when the hi fans are on. Expantion systems tend to run slightly higher pressures anyway.
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
Jan 23, 2015 01:13 PM
