power window motors
Old Mar 20, 2007 | 09:28 PM
sn8ke eatr's Avatar
power window motors
i need to change both my power window motors on a 93'z28. this shouldnt be that hard but anybody know any tips or things to look out for? someone told me i have to drill out welds for the motor regualtor and replace the welds with bolts? anybody know if this is true or not, any help would be great
Old Mar 20, 2007 | 09:30 PM
bombebomb's Avatar
You have to drill out the rivits, shoebox has an excellent tutorial on how to do it, now if I could only remember his websites name.
EDIT:http://shbox.com/page/windowmotor.html
and 93v8 beat me.
Old Mar 20, 2007 | 09:31 PM
93v8clone's Avatar
www.shbox.com;)
Old Mar 20, 2007 | 09:37 PM
Don't drill out the regulator rivets.
Old Mar 20, 2007 | 09:59 PM
Z95m6's Avatar
I suggest buying the motors from autozone. They're free life time replacements and are just as good as the stock motors.
Old Mar 20, 2007 | 10:47 PM
Voridaeus's Avatar
That's not saying much
Old Mar 20, 2007 | 10:48 PM
LT1_383's Avatar
Why do a job more then once? If the original lasted 10 years it's likely the new GM part will last about as long. I followed the shoebox site when i replaced my motor last year and was surprised how easy it turned out to be. I've done them before on other GM vehicles and actually removing the regulator can at times be a huge pain in the ***.
Old Mar 20, 2007 | 10:50 PM
Z95m6's Avatar
Yeah what i'm saying is a lot of people have the stockers fail under 5 years. I think I'm on four years with my autozone motors. So if they go out I go get a new one where as if I was buying new GM my wallet would be taking a big hit. I don't think most people get 10 yrs out of stockers. I bought my 95 in 01 with 80k miles on it and the drivers side was shot. The pass. side failed about 6 months later.
Old Mar 20, 2007 | 11:02 PM
My replacement GM motor (the one used in the replacement how to) has been in since 1999. Still working. The factory original motor in the passenger door is still working, too. 104k miles on my car.
Old Mar 20, 2007 | 11:06 PM
LT1_383's Avatar
My passenger side motor went out last year. 11 Years ~90k. Appeared to be original. Looks like there is a wide range of life expectancy with these motors.
Old Mar 20, 2007 | 11:09 PM
mrmint69's Avatar
I had the center spring device come off but the window still works fine. Just be careful with the regulator that you don't move it anymore than you have to.
Old Mar 21, 2007 | 04:55 AM
RE AND CHERYL's Avatar
I bought replacements from Advanced Auto Parts. Appear to be built well and no current limiters.
Re'
Old Mar 25, 2007 | 07:52 AM
01Z's Avatar
01Z
I pulled my window motor, cleaned and replaced the hardening lubricant in the gear area. I then soldered solid the bi-metal connector strip and my window operates perfectly - better than new IMHO.
Look for a user called wrd1972 and follow his post about fixing the original motor. I did what he said and have a relatively fast window with no issues. He saved me $60 per side = respect for life.
Old Mar 25, 2007 | 02:47 PM
dochidalgo's Avatar
Here you go
Regards
dochidalgo
Old Mar 25, 2007 | 10:26 PM
eeg3's Avatar
I need to fix my windows, too. Anyone know how much it'd cost for parts+labor to get the motors replaced?
