Power widow issue??? Possible motor replacement?
Old Dec 29, 2005 | 02:11 PM
nonamez28's Avatar
Well last night going down the road, i rolled the windows down, and saw that the passenger side window was going offly slow. .. Went to roll them back up and it went about half way... i tried to pull it up and roll it up at the same time, and didnt work..
Then i turn the car off and turn it back on, and hit the switch, and the window went up a little. I belive when i hit the switches i do hear a little click, so it think it would be the motor??
Opinions?
Also is a power window replace ment, a do it yourself job?? i am a DIY guy, so any help i can get would be great.
Thankyou in advance, Chase
Old Dec 29, 2005 | 02:15 PM
Honda Hunter's Avatar
Re: Power widow issue??? Possible motor replacement?
I believe Shoebox has a page on replacement and a "how to" remove the heat thingy that makes them power windows shut off. Both of mine do the same thing, very annoying. I plan on replacing mine asap.
Old Dec 29, 2005 | 02:42 PM
nonamez28's Avatar
heat thingy?
also can i have the link to the showbox? sorry im new
Old Dec 29, 2005 | 02:43 PM
http://shbox.com/1/how_tos.html
Sounds like you just need a motor replaced.
Old Dec 29, 2005 | 02:45 PM
nonamez28's Avatar
awesome thankyou very much!
Old Dec 29, 2005 | 03:10 PM
wrd1972's Avatar
I once replaced a motor with a brand new one and it actually went slower.
Turned out to be the tracks and the scissor lift mechanism were either gunked up or very dry.
I sprayed white litium grease in the tracks and window went up like it was on the juice.
I have seen many times where the motor is not the problem.
Its easy to replace.
Old Dec 29, 2005 | 05:58 PM
nonamez28's Avatar
hmmmm... well i will have to see when i take the door panel off...
Old Jan 4, 2006 | 10:12 PM
mike32's Avatar
Had the same problem with my wife's 97 and had to have the window motor replaced. Worked perfectly once new motor was installed.
Old Jan 5, 2006 | 08:10 AM
BlackbirdWS6's Avatar
same thing happened to me, same exact symptoms. replace the motor. Shoebox's instructions were great BTW.
-Brian
HectorM52
Jul 30, 2017 11:46 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Jan 5, 2015 07:14 PM
Jazsun
Dec 29, 2014 12:14 PM
