power locks don't work?
I have a 96 Z28. Everything works but the locks. I checked the fuses,good. When I hit the button, I hear a relay activating @ the glove box area.Any suggestions would be great. Thanks.
Re: power locks don't work?
I can manual cycle the lock. The locks make the same "relay " noise when pushing the button on the doors or the button on the remote entry. Thanks for any help,Troy.
Take the door panel off and see if you are getting power to the locks. (use a meter) My guess is that you are not, if both door locks are not working.
Anyone have a wiring diagram that can locate the common point between both door locks?
I have the actual GM manuals, they are @ 2" thick apeice. I guess I'll look in there. I' didn't know if there is a relay and maybe that went bad . Thanks for the suggestions,Troy.
