people that drive their cars without powersteering?
Old Apr 25, 2006 | 12:57 AM
  #16
thesoundandthefury's Avatar
Re: people that drive their cars without powersteering?
Originally Posted by bowtieman_racin
Noones said anything really good about it yet or if your running very big front tires, I may try to just put the alt in place of a/c and make the belt work around the p/s with an extra pulley or something. anyone else got any pictures of something like this? thanks,
You could set your accessories up like this guy did. (Turbo6 is his screen name.) Looks pretty clean considering it's a stock bracket:
Pic was taken from this thread: http://web.camaross.com/forums/showt...elocation+pics
Old Apr 25, 2006 | 03:51 AM
  #17
bowtieman_racin's Avatar
i like that I'd like to see the back of that pulley, guessing he just ran a long bolt through the original alt. hole? I'm sure I could find a pulley somewhere i guess getting the right size belt would be the only problem. thanks,
Old Apr 25, 2006 | 05:27 AM
  #18
Rashiki's Avatar
My P/S pump died slowly over time, so i noticed it was getting a bit tougher and starting to make noise, but i got used to it. Once it completely went to hell, i'd pray i didn't have to make any sharp turns, and even getting into my driveway was a chore. I'm not a huge guy, but i got by. Stock 245/50/16 tires all around. It was like heaven when i put my new pump in (eventhough when i was priming it, the pulley ripped part of my finger off ) and wouldn't go back. There is something with the gearing of the pump that makes them die out quickly, but if you look up Turn One, they take a stock pump and tweak it for 50 bucks so it's a more consistient output, and will last much longer. if i had the time, i probably would have sent mine out. I will the next time this one dies tho.
Old Apr 25, 2006 | 05:40 AM
  #19
huh never heard of them, I should go ahead and get a new pump though I get tired of the engine bay looking like crap from the stuff the pump throws out it doesn't really loose much fluid but makes a mess.
Old Apr 25, 2006 | 07:10 AM
  #20
Rashiki's Avatar
Here is a write up on turn one and p/s in general from GMHTTP http://www.gmhightechperformance.com...0602htp_power/
Turn one can be found at http://www.turnone-steering.com/
n-joy
Old Apr 25, 2006 | 10:38 PM
  #21
blackrat's Avatar
I installed one on mine after I burned through my second pump. I like it, definently looks better, and the feel is less floaty.
Old Apr 25, 2006 | 11:35 PM
  #22
can you just buy one from them or do you have to send yours in? how much does it cost? thanks
Old Apr 26, 2006 | 12:41 AM
  #23
blackrat's Avatar
Buy it directly from them, new pump, resoivoir, and pulley. IIRK it was a little over $200. Well worth it to me, I had already burned two pumps and each was over $100 itself.
Noenav
Mar 1, 2019 07:38 AM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
