P# for electric fans on 98-SS
Old Oct 25, 2004 | 08:19 PM
LT-14me's Avatar
Hello, both my electric fans are dead luckily its about 30* outside so my car isnt overheating too bad. It runs around 210*. Does anyone have the part#'s for the 2 electric fans? The primary and the secondary fan? Thanks
Old Oct 26, 2004 | 01:32 PM
LT-14me's Avatar
Re: P# for electric fans on 98-SS
little help?
Old Oct 26, 2004 | 05:53 PM
Compstall's Avatar
It would be awfully ironic that BOTH fans go bad at the same time. I would check the relay first. If you still want the part #'s for the fans I will look them up for you when I get home from work.
Old Oct 26, 2004 | 09:12 PM
LT-14me's Avatar
yeah thats what i was thinking. I know the secondary fan was dieing because i would run the a/c and the fan wouldnt move, i would then slightly tap it and it would spin then stop again. So i am pretty sure the secondary fan motor is dead. As far as the primary one..well, i have no idea where the relay is any ideas? I just stopped working about a week ago. damn electric fans...
Old Oct 26, 2004 | 09:23 PM
n2ceptor's Avatar
Most fan motors, you can pick up a your local parts store; around 30-50 dollars... If you need the GM #s, check Shoebox's website first... If its not there post up and I'll look....
Old Oct 26, 2004 | 09:31 PM
LT-14me's Avatar
who is shoebox?..lol yeah i figured the local autozone would have them just seein if i could get them for any cheaper of GM parts direct.com
Does this happen often? I mean Both of my fans are gone at 76k miles I tapped the main fan and nothing. It didnt even spin. The trouble code on my ses light is that electric fan motor is dead. But its been on for awhile. My secondary fan died in august, and my car was still running about 160*. Now this thing is runnen hot as a bastard. 210+*
Any ideas? Does it sound like just bad fans? Or is it the relay??
Old Oct 26, 2004 | 10:52 PM
n2ceptor's Avatar
I would guess first the relay or possibly bad temp sensor for the computer. located in front, not on the side of the head..... You could run a hot wire to the fan and see if it works.....
EDIT: http://shbox.com/1/4th_gen_tech1.html
Old Oct 26, 2004 | 11:42 PM
LT-14me's Avatar
It says for a 95 lt1 f-bod on the web site also i dont see anything about part #'s...maybe i am wrong. Thanks for the help
Old Oct 27, 2004 | 10:43 AM
LT-14me's Avatar
could it be anything else causeing the fans to die?
Old Oct 27, 2004 | 11:24 AM
Compstall's Avatar
Couldn't be anything other than what's been listed already.
Old Oct 27, 2004 | 12:51 PM
Just updated my part list with fan motor info including 1998 (see link in sig).
I would try to do some isolation testing to see if it is really the fan before going to the expense and trouble to replace it.
Old Oct 27, 2004 | 11:45 PM
LT-14me's Avatar
Thanks alot guys i appreciate it. I am going to do more testing 2 morrow but i am pretty sure that the fans are just dead. When looking at the volt guage its normal. All lights are normal no power drain that would be concistant with a shortage or anything. I think it just **** the bed. and thanks shoebox for the correct #. So the fan would fit in both locations? 1996-2002 (C60) cooling fan motor
(only listing is RH, but seems it should work for LH, too)
AC-Delco #15-8404 22104439 $41.90
Old Oct 28, 2004 | 07:28 AM
I don't see why the LH and RH motors would be different, but the parts book only listed the RH. Sometimes there are little quirks in the parts book.
Old Oct 28, 2004 | 01:28 PM
LT-14me's Avatar
I thought one was bigger then the other? Maybe i am wrong
Well, thanks for the help guys
Old Oct 28, 2004 | 09:03 PM
LT-14me's Avatar
i went to ac delco's website and all i found for a 98 camaro ss was part# PT189 Connector, Mot-Eng Cool fan (2 way female # 12101917) 13.93
Part# 158404
Motor Kit Eng cool fan (#22104439) 57.79
not p# 15-8404 22104439
anyone got a clue?
