Overheating?
Old May 13, 2009 | 10:40 AM
LSWHO's Avatar
Overheating?
My car is randomly overheating. I've tried to see if I can hear the coolant bubbling, but it's so quiet I can't really tell if the car is actually overheating or if it's the sensor.
It VERY quickly overheats while stopped, then cools off really quick when I get moving again.
What could be going on?
Old May 13, 2009 | 10:44 AM
johnny6's Avatar
Sounds like the fans aren't coming on, when you have it in park and it starts to get warm pop the hood to see if the fans are running.
Old May 13, 2009 | 12:51 PM
LSWHO's Avatar
The fans shouldn't come on at the normal temp. they come on well after where my car normally runs at.
It's heating up FAST. Like I come to a stop where the car is just past the first tick and withing 2 seconds it's trying to get to the red already.
That's not normal.
Old May 13, 2009 | 01:05 PM
johnny6's Avatar
So.......Are the fans coming on or not? Fans are what keep the temperature down while at idle, stop and go traffic etc. etc. Once you get going the fans shut off because the air from outside cools the radiator. And no, the fans don't come on well after normal temperature, if you do alot of city driving during the day they will probably never shut off.
Old May 15, 2009 | 07:03 PM
LSWHO's Avatar
The fans ARE coming on. It only overheats with the A/C on??
Could this be caused from the heat exchanger being clogged? I am not Mr. Cooling system.
There's nothing in between the condenser and radiator.
I bled the coolant system the other day.
Radiator cap appears to be working. I pulled the tab on it and it released some air.
Old May 15, 2009 | 07:29 PM
johnny6's Avatar
You need a really good flush, you have a clog somewhere.
Old May 15, 2009 | 08:15 PM
LSWHO's Avatar
Just flushed the whole thing.
Installed new thermo
and bled the system.
So far so good.
I'll keep checking over the thing for the next few days.
Old May 15, 2009 | 10:30 PM
dvdslw's Avatar
Sounds like a cooling fan problem. Look and see if they are working and if you have access to a scanner, hook it up and see exactly what the temp is and if the reading is really off (like -40) then suspect a faulty temp sensor.
Old May 17, 2009 | 10:32 PM
Fatdog2's Avatar
YEP.it's on the radiator.Previous posts have suggested this.Hope this helps.
Old May 18, 2009 | 12:44 AM
LSWHO's Avatar
...Just flushed the whole thing.
So far so good.
Thanks for the help, guys. See above.
damnyankee36
Sep 9, 2015 07:06 PM
Pwilson59
Sep 3, 2015 08:47 PM
Noct
Jul 14, 2015 01:18 AM
thenewkid
Jul 2, 2015 07:16 AM
warmeck
Apr 16, 2015 05:50 PM
