Is This Normal??
Is This Normal??
I've been running a 160* thermosat for a little while now and it runs real cool, whch I liked. But on the dyno, my air/fuel ratio was a low and it was suggested to me that 160* is too low ad I should run a 180*.
I thought running too rich and too cool also contributed to my stalling once and a while, so I've decided today to put in a 180* today. While doing this, I lost a little bit of coolant, and the thermostat seemed very long (it touched the bottom when I installed it). So to make sure everything was okay, I took the car for a 15-20 minute test drive and it almost overheated. It stayed at 1/4 before redline, and then started slowly creeping towards 260*. I took it back to the house and put more coolant in it, waited for about 5 minutes ad took it out again, no change.
Is this normal? I didn't think that 20* more would make me overheat, when with my 160* stat, I rarely even reached the half way point. Is something wrong, or should I jsut wait until the car cools all the way down with the new coolant in it before I test it again?
Re: Is This Normal??
I knew I forgot something. I don't think I even know how to do that. It's late now anyways. I'll have to wait til tomorrow and try to bleed the system. Thanks shoebox.
I think they (Summit Racing) might have sent me the wrong one. The thing was seemed too long, it fit, but the bottom of the thermostat touched the bottom of the thermostat housing. And that can't be right. It was about 2 to 3 times longer tha the 160* and the stock 195* thermostats I have in my garage. Also, I've never had to bleed it before.
Someone told me to do this:
But that didn't work. The thermostat is definitely the culprit. This caused me a lot of greif and extra work. I might not even be able to meet my GF in time. Summit Racing shall feel my wrath.
1. Car cold, and off, open the radiator cap, and fill it with 50/50 water/coolant to the top
2. Start the car and let the engine idle (You should still have the radiator cap off)
3. When the thermostat opens, you will see the water level drop dramatically, fill it back up to the top, put the cap back on, and your done.
WobblySausage
Oct 7, 2015 10:09 AM
. You may have gotten an LT1 thermostat by mistake. There is not a bleed procedure on the 3.4.
