Is This Normal?
Old Aug 31, 2005 | 07:08 PM
MarcR94v6's Avatar
Is This Normal?
Might be a dumb question, but it just didn't seem like it did this before I replaced and fixed things. Maybe it's just finally healthy, but...
When it hits 2nd or 3rd gear (not sure which), it pulls really hard and RPMS get to 5 or 6k in the beginning of the gear and fall back down quickly. And it makes a short burst of sound like a loud roar, which actually sounds kinda nice. This only happens when I push it to half throttle or beyond, sometimes a little less than half.
Is this just some restored power, or are my shift points off?
Old Aug 31, 2005 | 10:00 PM
Kataklysm's Avatar
Re: Is This Normal?
It revs high after shift then goes back down while in the same gear?
Old Sep 1, 2005 | 12:27 AM
MarcR94v6's Avatar
Re: Is This Normal?
Yes, Immidiately after the shift. I think I might post a video soon of the speedo and the sound of it.
Old Sep 1, 2005 | 12:50 AM
MasterEvilAce's Avatar
Re: Is This Normal?
It sounds like your RPM is going up, but the car isn't accelerating anymore. As if the car is in neutral and free-rev's then when it gets in the next gear the RPM goes to where it should be.
If this is the case, your transmission is slipping.
Old Sep 1, 2005 | 01:02 AM
MarcR94v6's Avatar
Re: Is This Normal?
God dammit.
Can anyone tell me what the name of my tranny is so I can look into how much a new one costs? It's an auto. I think it's 700R4, but I need verification.
Thanks.
Old Sep 1, 2005 | 02:32 AM
Re: Is This Normal?
94-02 F-bodies had the 4L60E automatic transmission
Don't freak out too quickly, what exactly did you change/fix, that you mentioned?
Old Sep 1, 2005 | 07:53 AM
teke184's Avatar
Re: Is This Normal?
even the v6s??
Old Sep 1, 2005 | 10:17 AM
Dave89IROC's Avatar
Re: Is This Normal?
Originally Posted by teke184
even the v6s??
what, the 4L60 E? yes, v6's too
Old Sep 1, 2005 | 11:23 AM
MarcR94v6's Avatar
Re: Is This Normal?
I restored a fair amount of power when I fixed the oil pressure sending unit, pcv valve harness, and cleaned the throttle body. The biggest gain was from the oil pressure. It started happening a little after I fixed the oil pressure. Actually, now that I think of it, sometimes when I'd pull out of a driveway, or just at a stoplight and would try to go, it would get stuck between gears, climb to mid-high rpms and then when it did shift, I would peel out. But it hasn't done that in a long time.
Old Sep 1, 2005 | 11:32 AM
HotwhipT/A's Avatar
Re: Is This Normal?
Yea that doesn't seem to be normal IMO. My guess is somethings wrong with the transmission. Sorry bro.
PopoFormula
Oct 12, 2015 04:19 PM
WobblySausage
Oct 7, 2015 10:09 AM
Hal Fisher
Sep 30, 2015 09:03 PM
SEOJustin
Sep 24, 2015 04:39 PM
plattted
9
Sep 20, 2015 11:23 AM
