Noise when off the clutch.....only sometimes?
Old Oct 28, 2004 | 08:02 AM
ChrisS95TA's Avatar
EDIT: Sorry wrong section Can this be moved to Drivetrain?
Well, I posted before about a noise...sort of metal on metal knocking sound when I have my foot off the clutch. It only seems to happen when the car is completely warmed up, ie - 200 degrees and driving for 10 minutes or more. The only problem is that it does not always happen when warmed up, seems to have a mind of its own. If I get under the car I can clearly hear it...I would think it was a sound coming from the cat but as soon as I push down the clutch it is silent. I have been told it is the throwout bearing, pilot bushing.......not sure. Has anyone else experienced this type of in-and-out noise with their M6? I really don't want to have any work done and if I have to I am going to upgrade the clutch and have everything done at once and I can't really afford spending $800-$1000 for transmission work right now. Hopefully I can baby the car as I usually do until i get married next summer and have some money to fix it .
Oh and there are no noises when driving, shifts fine (very stiff when cold but that is normal from what I read) and no noise when doing WOT runs shifting at 5400-5600 on factory tach.
Old Oct 28, 2004 | 08:13 AM
mc01ta's Avatar
Re: Noise when off the clutch.....only sometimes?
throwout bearing.....when you replace this you might as well replace your clutch/flywheel, etc. since you have to pull the transmission. I am doing this soon to my car, same problem.
Old Oct 28, 2004 | 08:33 AM
ChrisS95TA's Avatar
Since it is intermittent now do you think I have a few thousand miles till it is needed? If I wait to change it out could I potentially one day have something break and do serious damage? Or would it continually gradually make more and more noise until it would be obvious that it needed changing?
autoxr166
Sep 25, 2015 04:21 PM
rideordie
Sep 7, 2015 08:22 AM
colts0455
13
Aug 7, 2015 09:15 PM
GT what?
Jul 14, 2015 10:17 PM
colts0455
Jul 7, 2015 07:19 PM
