I pulled my tails off and tinted them, Now I've always known that the three wires going to the brake/blinker light bulb in the passenger side tail light have been spliced because of the butt connectors in plain view. I didn't know why though. So to make a long story short, I have never had any problems with the tails or blinkers except for replacing a couple bulbs. but this is where I'm at now
So when I went to check all the lights to make sure they were working they all looked good except for when I hit the brakes , none of the bulbs got brighter on the passenger side. I swapped bulbs with the other side and it did the same thing. Nothing changed on the passenger side when I hit the brakes, and the bulb I swapped to the driver side was working fine. so I look at the bulb wiring going to the specific bulb and the three wires going to the bulb have been spliced.. so i figured it was just a bad connection, I stripped them down and reconnected them. Still nothing , all the bulbs are working , its just that the one bulb on the passenger side doesn't get brighter when the brake is applied. any help?? I know the bulb is good because If I swap it with the working tail light on the other side the problem stays on the passenger side, all 3 connections (Black,Brown,Green) where the wires were previously spliced are secure, Do I need to trace the green wire back until I find a broken connection?
EDIT: Nevermind I would have to remove the tail panel to trace the wire.. Can I just splice 1 wire from the working side?? It seems to be the easy way out
So I spliced a wire in from the left side bulb that was getting brighter to the right side bulb and now I have brake lights, but now when I turn my left blinker on both tails blink, and nothing happens when I use my right blinker. this has turned into a pita. any help would be appreciated.
Sounds like you just need to do some wire tracing and find where the break is in the wire. That's the proper way to fix it.
Also, Butt-connectors suck; I highly suggest soldering and heat-shrinking them. Either that or get the butt-connectors that have the heat-shrink on them.
