need some advice.
Old Mar 8, 2013 | 12:10 AM
murph00's Avatar
need some advice.
So today I had a UCI ran at my dads dealership to see what needs to be replaced and fix on my 2000 canaro ss and they gave me a list, price witg labor only. no parts included. should I try a local mechanic to see i I can get a better price? and what wouls you all recommended is a must to be done first.
Old Mar 8, 2013 | 07:57 AM
GaryDoug's Avatar
Prominent Member
Re: need some advice.
I would focus on the P0336 and P1637 codes. The P0336 is a crankshaft position sensor fault and you need that sensor working to keep the engine running. It may be just a bad connection, nevertheless it is critical. The P1637 code indicates a problem with the alternator control line. A disconnect there will stop alternator operation and the battery will discharge, leaving you stranded, as will the P0336.
jj_burchiel
Mar 21, 2015 12:51 AM
jj_burchiel
Mar 5, 2015 07:05 AM
camy 1993
Feb 3, 2015 06:26 PM
tds1213
Nov 27, 2014 12:55 PM
Black01_Z
Oct 29, 2002 07:32 AM
