Need simple wiring help for DMH cutout
Old Apr 20, 2004 | 11:10 PM
Prince's Avatar
All I need to know is where I should tap into for the 12v source. I did a search and came up with the cigar lighter, but I've already tried that and keep blowing fuses.
Any ideas before I just pick something else?
Old Apr 20, 2004 | 11:54 PM
ucnu112's Avatar
I put a spade connector on mine and ran it straight to the fuse block by the drivers door. There was an empty spot in there, and I plugged it right in. Probably would be smart for you to put an inline fuse in it, though.
Fred
Old Apr 21, 2004 | 10:17 AM
2001NBMZ28's Avatar
I wired mine to the radio fuse inside the car because QTP recommends using a "switched" source for power. For ground I tapped into the black wire off the cig lighter.
Old Apr 21, 2004 | 11:16 AM
ppmz28's Avatar
I wired mine into an accessory input.... hope that helps
Old Apr 21, 2004 | 12:15 PM
Red96Lt1's Avatar
Yeah, tap into the fuse block. There are 3 different places. one for always on. one for acc on. and I think one for ignition on. Something like that. And for the ground, just ground it to a screw or something.
Old Apr 21, 2004 | 12:18 PM
Prince's Avatar
Thanks for the help fellas.
I just finished mounting the switch in the cd (junk) holder on my center console.
birdblack
Exhaust System
Jan 4, 2015 09:41 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
