Need help diagnosing a no start
Old Jun 2, 2008 | 03:35 PM
vin1382's Avatar
Got a problem with the 178K mile 96 trans am. On Friday at work it wouldnt start. it doesnt crank, however the dash lights up. In the past, I've had the security light come on and then stay on and then not be able to start it for 3 minutes. However this time its not the security light. I've also very sporadically had it in the past where this exact situation has happened where it wont start but with no security light, but after turning the key a few times it will crank and fire up.
Based on the above info, any ideas? Let me know if theres more information that I would need to pass on to help with the diagnosis
Since I am at work, it will be hard for me to work on it much unless I can fit in an hour here, an hour there. I am a relative mechanic newbie, but with good instructions I can probably figure it out. If i can't get anywhere in a few days I'll have to get it towed somewhere, but i dont know, and therefore dont trust any mechanics near my job (45 mins from home).
Thanks!!
Old Jun 2, 2008 | 04:08 PM
You might want to check to see if the purple wire at the starter solenoid is getting 12v when the key is in the start position. You can find wiring diagrams on my Tech Page, if you need to trace the problem out.
Old Jun 2, 2008 | 10:50 PM
vin1382's Avatar
ok thanks, ill see if i can get another hour to head out to the parking lot tomorrow.
Old Jun 3, 2008 | 11:43 AM
Slick_Sammy's Avatar
failing neutral safety switch? jerk the gearshift around a little to see if that does anything. do you hear anything when you turn the key? sound like the starter bendix is engaging with flywheel at all? tap on the starter with a hammer to see if it will free something up. pull battery cables off and check for corrosion/bad connections. you can have enough voltage to power gauges but not near enough for the starter to engage.
Old Jun 4, 2008 | 04:48 PM
vin1382's Avatar
ok, i am going to try your suggestions now while i have some time. got 1 more day before i am gonna tow it!
Alex Barnes
Jan 24, 2015 10:21 PM
Amshnock
14
Jan 18, 2015 11:47 AM
USAirman93
Nov 24, 2014 03:37 PM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
