Bought myself some 8.5mm MSD wires about 6 months ago and finally got round to fitting them today.I started with the drivers side as it looked easier,took me about 40 minutes.Then for the passenger side,what a joke,took about 4 hours
In all honesty it looks to me that it would be easier to change the plugs than the wires,what a pain in the a$$,well forearms actually
.I look like I've been arm wrestling a rose bush
I managed to do it without removing anything other than the serpentine belt,so not too bad in that department
I think I'd rather do another water-pump than the wires again though,not a nice job.
Mark.
.In all honesty it looks to me that it would be easier to change the plugs than the wires,what a pain in the a$$,well forearms actually
.I managed to do it without removing anything other than the serpentine belt,so not too bad in that department
.I think I'd rather do another water-pump than the wires again though,not a nice job.
Mark.
Quote:
I just used zip ties,as the 8.5mm wires don't fit in the stock looms,as mentioned above,you could buy some after-market looms but to be honest you won't see them once they're installed.Originally Posted by 97greenie
I'm getting ready to do the same wires.Did you buy new looms or just use zip ties?
To aid removal of the old wires cut one end off and they pull right out
.Quote:
Yeah,would like some longtube headers some time in the future as I plan on keeping the car for a while Originally Posted by 2000GTP
Put on some long tube headers and an over-the-valve cover wire setup and wire/plug changes will get much easier.
.Registered User
easiest way to do the pass side, unbolt the pass side engine mount through bolt, and jack up the engine
