MPG of a Lambo,power of a Geo
I bought my current 94 Z with a busted Opti.After replacing it, the first thing I noticed was it was real slow compared to my last four Z's,and im only averaging about 170 a tank,about 11 mpg.So far no codes but i have replaced coil,wires,plugs,opti,water pump,cleaned out throttle body,new coolant temp sensor,ect.It idles smooth as butter, shifts just fine,just no power,and the o2s look fairly new.I cant get any info out of the last owner cause he only had it a week then Opti went out.What should i be looking for?
If you find that the tach is accurate, this might be a clue about the problem (slipping trans?).
I"ll check that!If I punch it from a dead stop,it shifts just fine in all gears,and ill check the rpm again .I was just going by what i thought i rememberedI was thinking also that someone told me if the gromet on the map sensor is rotted, it might give it a false reading and ritchen it up.
