Missing Above 5K RPM
Old Oct 24, 2004 | 03:54 AM
OutsiderIROC-Z's Avatar
Missing Above 5K RPM/Bad Fuel Maybe??
Here is what my 95 Z28 just started doing. It pulls like it always has up to just over 5000 RPM and then it pops and sputters it's way to 5800 RPM or so and then shifts. I think my 85 IROC-Z with a TPI acted like this when the MAF sensor went south, but am not sure.
Any advice/experience would be much appreciated.
Old Oct 24, 2004 | 12:03 PM
Rice Killer87's Avatar
Re: Missing Above 5K RPM
sounds like its either spark or fuel.
try checking the fuel pressure first,thats the easiest.
Old Oct 24, 2004 | 02:20 PM
ChrisS95TA's Avatar
Could be plugs, wires, coil, fuel filter (often overlooked). People will tell you to scan the car and figure out what is going on. Scan for knock retard too, I had up to 10 degrees or so before I installed an LT4KM, now basically none (some knock retard on hard shifts, but I seem to be able to avoid this now). Good luck, there are so many things that can affect high RPM performance.
Old Oct 24, 2004 | 10:04 PM
izzyz28's Avatar
I had the same problem on my car. It turned out to be a corroded coil wire. The wires were only a few months old too. Check the simple stuff first like fuel pressure, cap an rotor, corrosion, etc..... Good luck.
Old Oct 24, 2004 | 11:07 PM
camaroKid223's Avatar
i had something close to that diff rpm's if i remember right, anyway i did coil, coilwire, and fuel filter and that fixed it. not sure what one of them fixed it though
Old Oct 25, 2004 | 02:10 PM
I am wondering if I got a tankful of bad fuel.....
jocamino
May 14, 2015 07:37 AM
Cam's maro
Mar 24, 2015 08:09 PM
DetroitZ28
Feb 13, 2015 07:33 AM
sleeperZ96BT
Jun 5, 2005 09:33 PM
