milled heads = longer pushrods needed right?
looking into some milled stock heads. they have been cut .030", for that i would need to pick up some 7.425" pushrods in place of the stock 7.4"
correct?
grrr...this "budget heads swap" is becoming much less budget!!!
correct?
shorter....DOH...that's what i meant.
since the intake doesn't seal any oil in...i can't imagine .03" change in position would cause a problem.
thanks guys.
so is the 7.375" (.025" shorter) close enough?? even though the heads are milled .030"??
i suppose that question is better suited for the ls1 forum...since you dont' have to set valve lash on ls1 rockers.
If the intake doesn't seal any oil, I guess it's just a myth that the rear of the intake leaks oil
The lifter valley is right below the intake so of course the intake seals oil. The area of concern for milled heads is that the intake ports from the heads to the intake align correctly and don't leak.
