Mild 10sec LS1 Buildup $4500
Old Feb 21, 2005 | 09:58 AM
tx_lt1's Avatar
This is what i have planned for June:
Engine: 224/228 114lsa .590/.590 cam, lid, lt headers, true duals, 36#-40# injectors, 100 dry shot n2o, dyno tuning, stock heads, msd box w/ timing retard.
Driveline: 3000 stall, 3.73's on stock 10bolt, ET streets
Suspension: sfc's, beefy torque arm, adj. panhard, stock springs/shocks
Chassis: drop weight to around 3200-3250 w/ driver.
I expect the mods to run under $4500k and put me somewhere around 370rwhp/370ft-lbs without spray and go 11.60's. With a 100 shot I would hope for 470rwhp/540ft-lbs and go 10.60's-10.70's spraying off the line w/ a 1.5x 60'.
Does that sound realistic to you guys?
Old Feb 21, 2005 | 10:35 AM
Spinner's Avatar
Re: Mild 10sec LS1 Buildup $4500
Nitrous, possibly. Motor, no way. Thats not enough converter.
Old Feb 21, 2005 | 12:56 PM
teke184's Avatar
i honestly don't think the 10bolt will last more than a few runs with slicks.
Old Feb 21, 2005 | 12:59 PM
stars1010's Avatar
I agree
Old Feb 21, 2005 | 01:31 PM
stik6shift93's Avatar
Actually it'll probably hold up just fine, auto's are much easier on the driveline than manuals. I know of several guys around consistently running 10's on 10 bolt rear ends.
Old Feb 21, 2005 | 01:41 PM
tx_lt1's Avatar
So as long as the rear end holds i'll be in the 10's correct?
Old Feb 21, 2005 | 05:00 PM
Spinner's Avatar
Needs more converter. Skinnies would help immensely. Depends on if you can hook or not, how good the tune is, etc. But definetly doable.
Old Feb 21, 2005 | 07:01 PM
BirchMan98z's Avatar
Heads/cam + higher stall + slicks would get you 10's easy, low 11's without breaking a sweat at the very least. low 10's on a mild shot of n2o.
Should be no problem getting 10's... once. Then you'll tow your car home.
Old Feb 22, 2005 | 09:10 AM
tx_lt1's Avatar
Ah well, 10bolts are gonna break, gotta live with it =). I was just wondering though if I understand convertors correctly, but wouldn't a 3000-3200 stall allow me to launch at 3000-3200 rpm? If so, that's where it's gonna make peak torque with the spray, so why wouldn't that be enough convertor? Why would I want to launch at say 4000rpm where the torque is lower?
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Hal Fisher
Sep 30, 2015 09:03 PM
Kawi
Sep 28, 2015 09:01 AM
DelSoto
Sep 19, 2015 05:31 AM
