Mechanical or electrical aftermarket gauge
Old May 28, 2007 | 07:31 AM
always faster's Avatar
I wanna purchase 2 gauge for my car from the ultra lite autometer series:
-Oil pressure gauge
-Water temperature gauge
I was looking at the mechanical one and the short sweep electrical.
Wich one do i choose
And also how do i install those because i dont wanna drill anything in my motor.
Old May 28, 2007 | 07:54 AM
mdacton's Avatar
get the electric.
Any failure of tubing will leak the hot fluid inside the car.
Electric uses a sending unit......the holes are there allready so no drilling required...just a hole thru the firewall for the wires.
Electric is alot safer.
Old May 28, 2007 | 07:57 AM
Originally Posted by mdacton
get the electric.
Cool thanks you ve help me out for two threads in less than 5 minutes your a king
But can i ask you where are the hole for each one:
-Oil pressure
-Water temp
Old May 28, 2007 | 08:03 AM
mdacton's Avatar
-Oil pressure
-Water temp
the temp goes in the head......you have a plug in the pass side now, the factory sending unit is in the drivers side.
the stock oil sender is behind the intake.....there is a plug on the side of the block over top of the oil filter you could use....
more than likely the gauge/sending unit will come with the adapters you will need
Old May 28, 2007 | 08:20 AM
Thanks for the help
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
Moshbmx1
Feb 17, 2015 10:51 AM
99TransAmWS6
Feb 12, 2015 07:23 PM
Jazsun
Dec 29, 2014 12:14 PM
5.7L 00 SS
Aug 6, 2002 07:01 AM
