LT1 engine harness wiring diagram?
Old Oct 1, 2007 | 09:38 PM
drptop70ss's Avatar
Does anyone have a listing or wiring diagram for the 3 connectors to the engine harness? They connect to the under dash harness behind the passenger side kick panel, I believe one is blue, one black, one white..I have a complete 1994 LT1 engine with its wiring harness and I want to tie this harness into an older 60s car. I have no wiring diagram to know what wire is what on those connecters, I have found the PCM pinouts but nothing for those 3 connectors. Anyone have anything?
Old Oct 1, 2007 | 10:52 PM
http://shbox.com/1/harness.htm
http://shbox.com/1/harness_connector_faces.htm
Old Oct 2, 2007 | 04:15 AM
drptop70ss's Avatar
Thanks, from your picture I can see what I need...the connectors C210 C220 and C230 that are in the passenger compartment, is there a listing or diagram to where those lines go inside the car? I have that complete harness still on the engine but want to tie those 3 connectors in to another car without the factory under dash harness. Thanks!
Old Oct 2, 2007 | 07:02 AM
The second like has info of what each wire feeds. Is that not what you need?
Old Oct 2, 2007 | 03:37 PM
drptop70ss's Avatar
Not sure, I dont think so..I want to know, if I had the factory under dash harness, is where the wires are going under the dash from those 3 connectors..basically I need a wiring diagram for the under dash harness and harness that runs out the firewall on the drivers side. I have checked your awesome site but think I only found engine to PCM wiring diagrams and not the under dash/left side firewall harness which has the ABS and front lamp harness. Hope I am explaining this ok.
Old Oct 2, 2007 | 03:54 PM
Well, the diagrams are spread all over the place, depending on what the wires go to, so there is not one diagram that follows all those wires to their end.
If you are going to put this into a car that won't even have some of those things, why do you even care as long as you know what the wires are for? If this is real important, I would suggest you buy a used factory manual and then you will have all the wiring diagrams and explanations you could ever need. I am not bustin' on ya', just telling you that it would take many, many diagrams to fully trace all the stuff in the car.
Old Oct 2, 2007 | 06:29 PM
drptop70ss's Avatar
Just need to know what they are for, but I havent seen that anywhere yet, or maybe I just dont know how to read the diagrams. Now that I know what the plug numbers are maybe that will help..as far as knowing them all, I want to incorporate as much as the newer car stuff as possible and just remove things like ABS.
Old Oct 2, 2007 | 06:35 PM
Again, this link has all the info for each wire on each plug. There are tabs at the bottom of the page for each connector you seek. I guess you are missing it.
Old Oct 2, 2007 | 06:40 PM
drptop70ss's Avatar
got it, I missed the tabs at the bottom. Thanks for all the help, I really appreciate it!
willismoons
Feb 14, 2015 08:42 PM
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
