LS F-Body power steering cooler question
My Camaro has a power steering cooler inserted in the top cooling hose. Does this circulate power steering fluid through it or does it allow coolant to circulate through the pump? Thanks
Re: LS F-Body power steering cooler question
Power steering fluid circulates through this cooler into a jacket around the engine coolant, it transfers heat into the engine coolant as it passes through.
Michael- |
I know a number of other cars use a small radiator type cooler for the power steering. I asked the same question at LSTech and a guy their said that radiator coolant circulates through the pump jacket. How sure are you about the PS fluid flowing through the cooler? Thanks
I'm positive the PS fluid runs through a thin jacket of the part in the radiator hose. In fact that part is called the "power steering cooler." If you don't believe it, take off one of the hoses that comes from your pump to the cooler. Its only held on by a clamp so it'll be a simple procedure. I'll bet power steering fluid will come out of it. Who even told you otherwise was either messing with your or doesn't know jack.
Unfortunately I learned all about this when mine started leaking power steering fluid into my coolant. Now thanks to GM wanting to rape people for parts, I'm running an aftermarket heat sink design mounted elsewhere. |
Originally Posted by BadgeZ28
(Post 4153794)
-Michael |
I ended up buying a used motorcycle oil cooler off ebay for $8 delivered. I cleaned it out and just need to get under the car now and find a good place to mount it.
Originally Posted by SilverStreek
(Post 4254564)
Ummm......pretty sure, I bought a used power steering cooler on e-bay, and installed it myself!! LS1's came stock with these, LT1's did not, and the hydraulic steering fluid overheats and fails on road course track days! ;-)
-Michael |
Originally Posted by Greed4Speed
(Post 4256611)
Not all LS1's came with them.
to 2002 f-bodies, not before. Not all f-bodies had these installed from the factory. I am sorry that my statement was confusing and misleading. Thanks for straightening me out. |
Wrong...wrong, ok, read: These were only available from the factory on f-bodies from 98 up w/a package that came with 17" wheels and then on all V8 models from IIRC 99 up.
The LS1 models started in 98. Not all 98 f-bodies came with a power steering cooler thus my comment, "Not all LS1's came with them." |
That is what I said.....thank you for agreeing with me!!
ps coolers came on all the SS', Ws.6's, and Firehawks from 98 or 99 on. They came in every v8 in 02.
Very neccesary in ls1 cars since they are creating may more output then needed, so they heat up. The LT1's ps fluid reservoir is mounted off the engine so it doesn't have as much of an overheating problem. The design of the cooler basically has a thin double wall. The coolant passes though the big tunnel, and the ps fluid is pushed through a maze of small tubes in that double wall. Supposedly it's a decent system but auto-x'ers still tend to cook their pumps. Mine failed and allowed coolant into the reservoir, taking out an alternator and basically making my life a living hell before I figured it out. |
(Post 4262155)
The way your statement reads is they were available on f-bodies as in all f-bodies from 98 up. If you put both your statements together you get all LS1 f-bodies from 98 up. Which is incorrect. It is more specific than that and not saying which one would lead someone to think that all Z28s or Formulas came with them when they didn't. |
(Post 4257584)
......Not all f-bodies had these installed from the factory......
Back on topic, P/S fluid goes through the cooler, no coolant flows to the pump.
(Post 4325081)
That is what I said, nowhere did I say all LS1's had these, I only stated that it was available on the LS1, but not on the LT1......wow....good job of going off topic
Why are you even worried about the topic when the thread is 4 months old and you are part of it going "off topic?" The fact still remains that you gave erronious information due to the lack of details or you didn't know the difference and you are just playing it up like you did. Stop ressurecting it already. |
