Low Voltage
Old 08-05-2005, 09:19 PM
GMH94Z28's Avatar
Low Voltage
Does anyone else’s voltage drop to the red when you turn on the headlights? Thanks
GMH94Z28 is offline
Old 08-05-2005, 09:26 PM
MarcR94v6's Avatar
Re: Low Voltage
That doesn't sound normal, it happens ONLY when you turn on the headlights and no other time??? If so that sounds strange and I don't know what to tell you, but someone else might. You may need to get your alternator checked at a auto store and get a new one like I did. Good luck.
MarcR94v6 is offline
Old 08-05-2005, 11:03 PM
GMH94Z28's Avatar
Re: Low Voltage
I should have been more descriptive in the problem. It does it when i am stopped at idle. I have the hypertech under drive crank pulley and when i turn on my A/C it drops down some but not in the red like the headlights do. Thank for the reply
GMH94Z28 is offline
Old 08-05-2005, 11:33 PM
1crazylt1's Avatar
Re: Low Voltage
i have the march pulley kit and it does the same thing at an idle but i think its normal for the pulley kits i mena correct me if iam wrong i have a brand new batterie and alt n it still does it
1crazylt1 is offline
Old 08-05-2005, 11:37 PM
GMH94Z28's Avatar
Re: Low Voltage
Thanks for the info
GMH94Z28 is offline
Old 08-06-2005, 12:29 AM
V8 Slayer's Avatar
Re: Low Voltage
Mine drops to red when im idling for more than 15 minutes with AC on full, music blasting, headlights and foglights on. Get rid of the underdrive pulley.
V8 Slayer is offline
RUENUF
03-13-2016 03:37 PM
speedracer1280
09-08-2015 06:12 AM
WPHIG2
08-27-2015 06:37 AM
08-07-2015 01:26 PM
C4m4roJoe
07-19-2015 10:59 PM
Quick Reply: Low Voltage
