loose hatch?
Old 04-10-2004, 09:30 PM
blackbirdta's Avatar
loose hatch?
every time i hit a bump my hatch rattles (i know...not too shocking...)i finally took some time to look at it and if i close the hatch i can push on it and it moves up and down...is there a way to tighten the latch or anything so it doesnt rattle? thanks
blackbirdta is offline
Old 04-10-2004, 10:05 PM
There are rubber bumpers on each corner at the back. Screw in or out to adjust the tension.
shoebox is offline
Old 04-11-2004, 01:03 AM
ill take a look at that tomorrow...thanks a lot!
Old 04-11-2004, 02:01 AM
RE AND CHERYL's Avatar
The rubber stops will only help if the hatch is sitting low when it is shut. To make it line up with the quarter panels you will have to adjust the rubber bumpers and the latch. The latch is located behind the carpet and can be adjusted up and down by loosening the bolts that hold it.
RE AND CHERYL is offline
Old 04-11-2004, 02:05 AM
scoobysnax83's Avatar
All the squeaking is at the latch. A cheap fix that worked for me is to wrap the latch piece on the hatch with some electrical tape. Takes a little more effort to close, but doesn't squeak at all.
scoobysnax83 is offline
AviatorDave
12-19-2016 06:35 PM
9t4lt4z28
10-02-2015 10:28 AM
92_RS_305
09-08-2015 07:47 PM
Z28-50
08-07-2015 01:22 AM
MikeWhitener
08-02-2015 06:17 PM
Quick Reply: loose hatch?
