longtubes and lowering
Old Sep 1, 2008 | 03:53 PM
1997whitez28's Avatar
What is the max to lower the car with and without Longtubes. someone had a lowered camaro and it was nice it was prolly a 2" drop.
Old Sep 1, 2008 | 03:58 PM
sn8ke eatr's Avatar
well the clearance varies depending on what brand of longtube you choose. offhand i recall pacestter having one of the best ground clearnaces. i have pacestters on my car and theres plently of room, but my cars not lowered. i think 2 inches is starting to push it, and more and you might be limited to mid legnths but i could be wrong
Old Sep 2, 2008 | 01:41 AM
SStupid's Avatar
I wouldn't drop your car at all if you install LTs.
Old Sep 2, 2008 | 04:47 PM
The reason is because ......................
I hit a big object in the highway and now my passenger side unibody it smashed up and thank god the door closes good. Either drop it if it helps or put a body kit on it or bondo or even a new panel. I don't have a welder.
Old Sep 2, 2008 | 05:16 PM
Ta4life's Avatar
My LPP headers clear great....id say 1.5- 2" would still be decent with them
Old Sep 2, 2008 | 05:26 PM
The_Bishop's Avatar
Wait... What?
If you bashed up the rocker panel, lowering the car will not help with that at all.
Old Sep 2, 2008 | 05:35 PM
TeamingTealZ28's Avatar
Maybe...so its lower u cant see the damage?
Old Sep 2, 2008 | 06:33 PM
Green96Z's Avatar
So the actual body is messed up? Get that fixed.
That said, my Kooks tuck up very nicely and my y-pipe still occasionally scrapes speed bumps at stock height. I wouldn't drop it at all.
Old Sep 4, 2008 | 11:39 AM
I think it would be cheaper if I lower it then fix the panel you can't see it unless its parked on a hill or if you bend down. they would have to take the door off and pull it out and out a new panel and im guessing $2000 but for now all I can afford is to lower it or bondo.
Old Sep 5, 2008 | 07:12 AM
2000GTP's Avatar
At stock ride height, I have a little less than a soda can distance from the headers to the pavement. Factor in a two inch drop on top of that and you can get a visual idea of what kind of clearance you are dealing with. People have done it, but you definitely have to mind your surroundings, otherwise you will be dragging and banging your exhaust real quick.
Old Sep 7, 2008 | 08:55 AM
maybe2fast's Avatar
I scrap my pacesetters without being lowered...
Old Sep 7, 2008 | 10:16 AM
JMG97SS's Avatar
I have hookers and theres no way Ill ever lower the car now. I was planning on it but I scrap now if Im not careful.
Old Sep 10, 2008 | 04:42 PM
SStupid's Avatar
I had a similar issue with my wife's Civic Si. They had to remove the door, the side window, and cut out the rocker panel piece that actually stretched from the front of the door to the back wheel, then paint the whole side of the car from the door backwards. It was a $3.5K job.
Old Sep 12, 2008 | 11:24 PM
yup
Mine looks the same as that. My door closes good just the panel is shot. Thanks for the photo shows that you care lol. Mine is alittle bit steeper. I hope its not going to be that much :-(
tdigger9899
Sep 7, 2015 10:56 AM
97SSdude
Aug 21, 2015 09:36 AM
jbc3
Jul 28, 2015 12:24 PM
mrwz28
Jul 8, 2015 09:11 PM
