Long term storage (2+ years), what should be considered?
Due to the military I will be away from my Z in my sig for the next 2 years
. I already ran fuel stabilizer in it, have disconnected the battery, it is up on jack stands with a car cover over it, and have a couple open containers of baking soda in the car.
Is there any thing else I should do to it for storage for this long? The most it has ever been in storage is about 10 months, and usually store it every winter for about 4-6 months. Each time I have pulled it out of storage it has always fired right up. Can or should I be expecting anything for this long period of time?
. I already ran fuel stabilizer in it, have disconnected the battery, it is up on jack stands with a car cover over it, and have a couple open containers of baking soda in the car.Is there any thing else I should do to it for storage for this long? The most it has ever been in storage is about 10 months, and usually store it every winter for about 4-6 months. Each time I have pulled it out of storage it has always fired right up. Can or should I be expecting anything for this long period of time?
If it was me I would have someone fire it up every few months to keep the seals from drying out. My old Z would leak transmission fluid really bad after long storage. Might not have that option though.
depending on the location of storage....might be worth blocking off the exhaust pipes and intake....keep critters out.
and are the jackstands putting the suspension undder load? i would not store it on the frame. car is designed to sit on a loaded suspension.
stands under the rear axle, and under the front arms
Let me store it for ya, not too far away and I'll drive it every now and then ;-)
Sounds like you have it mostly figured out, if its possible the best thing would be to drain the has completely out of it.
I would also look into draining the oil as well. Sounds wierd but for sitting still that long and not being started, it will actually allow condensation inside the pan and start rusting from the inside out....not good.
Just my 2 cents.
Just my 2 cents.
NewsBot
Jan 21, 2015 06:10 PM
NewsBot
Dec 3, 2014 12:30 PM
owen66
Nov 30, 2014 04:21 PM
