Left turn signal doesn't blink.
Old 08-18-2004, 06:42 PM
ScreamnChicken's Avatar
When I put the left turn signal on, the light comes on, but it won't blink. However, when I but my hazards on, all the lights blink. Any ideas.
ScreamnChicken is offline
Old 08-18-2004, 07:29 PM
red96taA4's Avatar
Re: Left turn signal doesn't blink.
check relays. its happened to a friend of mine...but im not sure what the reasoning was, ill see if i can find out.
red96taA4 is offline
Old 08-18-2004, 09:18 PM
I replaced all of the bulbs, no luck...I checked the flasher, no luck...I wouldn't think a fuse would just cause half the light to not turn on. I found out that when I put just the lights on, all the lights work. However, when I put the blinker on, or put the breaks on, the 2nd light from the outside goes completely dead, so I am thinking it is a wiring problem or something???
Old 08-20-2004, 10:29 AM
blind527's Avatar
i have brought my car in so many times to be looked at for this "electrical problem."
at first my right fog light would go on and off, and my right blinker wouldn't work and my left one would. after 2 times of bringing it in, everything worked for about 3 days, and after that my left fog light when out and NO blinkers work. the only time a blink DOES work is if i put my headlights on, then about half of my lift fog light goes on, and my right blinker SOMETIMES works. its REALLY pissing me off.
if i bring it in *keep in mind its under warranty* what should i tell them???? should i just be like rewire everything?!?!?
blind527 is offline
stangspank
11-13-2015 01:02 PM
CaRParts102
12-06-2014 08:45 AM
vinnyxgunz
08-28-2002 09:41 PM
Darth Xed
13
07-22-2002 12:45 PM
CMJ917-95CMO
06-19-2002 09:10 PM
Quick Reply: Left turn signal doesn't blink.
