Left Front Turn Signal/DRL...
Subscribe
Feb 9, 2008 | 03:57 PM
Ok, so my left turn signal light indash stays on and so does the rear blinker itself. My DRL doesn't turn on, so I figure that it's just a bulb that needs to be replaced. They're 3057s right?
Also, what's the easiest way to replace the bulb? Just go over and under the headlight housing? I don't have a toolset.
Reply
Feb 9, 2008 | 04:43 PM
Yeah they are the 3057LL bulbs. I replaced mine by going under the car, there is a flap that you fold down to get to the bulb. It has 2 bolts holding the flap, take those off, fold down, I think you have to take 2 or 3 other screws out to remove the blinker. Change out the bulb, put it back on and you're done.
Reply
Feb 9, 2008 | 04:48 PM
On my 79Z that happens when the hazzards are turned on by the keys hitting the switch.
Reply
Feb 9, 2008 | 06:53 PM
Quote: Yeah they are the 3057LL bulbs. I replaced mine by going under the car, there is a flap that you fold down to get to the bulb. It has 2 bolts holding the flap, take those off, fold down, I think you have to take 2 or 3 other screws out to remove the blinker. Change out the bulb, put it back on and you're done.
Do you know the bolt sizes by chance? I'm sure I could use tools at work as long as I'm quick with them.
Reply
Feb 9, 2008 | 10:28 PM
I think the bolts holding the flap are 10mm, the bolts holding the turn signal are 8mm, might be smaller though, I don't remember the exact size. Sorry. But once you have the right size it shouldn't take long at all to change out.
Reply
Feb 9, 2008 | 11:05 PM
Sounds more like the DRL module might be bad. Same thing happened on my 97 except it was the right side that didn't work. Hopefully it's just the bulb, but if that doesn't work it's probably the module.
Reply
Feb 10, 2008 | 01:41 AM
Thats weird this is posted just now. lol. I just did the 97+ dash swap and my left turn signal light is sticking on when I use the turn signal it seems fine, but it likes to stay on...wtf
Reply
Subscribe
