Leaking Freon out back of A/C Compresser
I replaced my engine this winter and I went to recharge the A/C but the freon just leaks out behind the A/C pump where the hosed attach. Is there a O-ring or something back there I should have replaced?.
I am going to tear into her this weekend but wanted to know if I need to run to the dealer**** and get an o-ring.
Re: Leaking Freon out back of A/C Compresser
Originally Posted by fastchevy
Hopefully they will give you the correct ones. They aren't rubber O rings but a metal 'crush' O ring/gasket.
Hmm so once you take it off from the back once you have to replace them?
Mine is leaking fron their to after taking the engine out
