View Poll Results: LE2 or Charger?
LE2 heads and cam package
12
66.67%
Supercharger w/ ~7-9 PSI
33.33%
Voters: 18. You may not vote on this poll
LE2 or Supercharger? Help me choose!
Old Jul 29, 2006 | 11:52 AM
VK's Avatar
VK
I can't seem to make up my mind on what i want to spend about 2-3 grand on for performance. I've talked to friends and some other F-body owners, I even talked to LE himself. I just need alittle more help with this, so here is my setup.
95' z28
BUILTA4 w/ 3.42 gears and 10-bolt
stock bottom end 350 w/ 85,000
Portmatched Heads and intake
1.6 RR from Comp Cams
Hardend pushrods w/ guideplates
ARP headbolts
Fel-pro headgaskets
LT4 Hotcam w/ valve springs
Pacesetter LT w/ ORY and flowmaster cat-back
Poly Engine and Tranny mounts
Strange Axle rearend parts
!AC !AIR !EGR !CAT
255lph Intank pump
I would like to get a supercharger so i'm not going back to redo the heads and cam i just did 5 months ago. I'd like to get alittle more out of all that money before i redo that instead of upgrading elsewhere.
So, i just need alittle help, thanks!
Old Jul 29, 2006 | 12:02 PM
2000GTP's Avatar
Re: LE2 or Supercharger? Help me choose!
Personally, if I spent the money to upgrade the heads/cam a few months prior, that would be one of the last things I would consider upgrading again. I would do the supercharger.
Old Jul 29, 2006 | 01:05 PM
joe-96z1le's Avatar
Its very likely your stock shortblock is gonna last longer w/ the heads and cam package than it will with a s/c. And unless everything you buy is used, a s/c kit with the supporting mods will cost a bit more.
Old Jul 30, 2006 | 01:37 PM
OBE1 95Z28's Avatar
Stock pistons are not going to handle a SC for very long. New parts to do a supercharger properly, not including the engine rebuild you're going to need later, will cost $4k (blower, ignition system, larger injectors, dyno tuning, fuel pump upgrade).
Old Jul 30, 2006 | 03:56 PM
crushah's Avatar
I would add cubes w/all forged internals first since the heads and cam are already upgraded, then supercharge it later.
Old Jul 30, 2006 | 07:09 PM
VK's Avatar
VK
choices... damn lol
Old Jul 30, 2006 | 07:12 PM
Camarocracy's Avatar
You could always run nitrous.
Old Jul 30, 2006 | 10:42 PM
VK's Avatar
VK
I do have a bottle, just that is all i have. Though that is one of the most expensive parts. Just would like to have all the power on the street as well as the strip.. and the bottle is just alittle too dangerous and illegal.
Old Jul 30, 2006 | 10:55 PM
Ðenial™'s Avatar
mite i suggest instead of spending that money on a blower, you just get a bigger crate motor...
Old Jul 31, 2006 | 06:21 AM
teke184's Avatar
not many LT1 crate motors available...
like everyone said...it's a crap shoot as to how long the motor holds the boost. you could be fine for 3K miles or 30K miles.
maybe start with a bigger cam and keep saving for an engine rebuild later.
Old Jul 31, 2006 | 09:22 AM
VK's Avatar
VK
Sounds like heads and cam might be the way most poeple go. I do love that whistle though!
Old Jul 31, 2006 | 09:32 AM
BlackbirdWS6's Avatar
if you want the whistle, get a edelbrock TB. Mine whistles like a blower lol. JK. I would go with the H/C only because it will last longer than the blower. Sucks to redo all that stuff again but when its all said and done, it will be worth it. Good luck with your choice.
-Brian
Old Jul 31, 2006 | 12:12 PM
93redBirdMan's Avatar
The LE2 motor wont last long either if he's reving it to where the real power is. Yea I'd honestly say get a crate motor 355 from one of the supporting vendors and throw the LE2 package on that. Or if you want better gas mileage and want to spend more money, throw a procharger on it
Old Jul 31, 2006 | 04:26 PM
ztwenty8's Avatar
i second that, you allready got the heads and cam. youll have more power out of your engine and also i will be able to hold up better to if you do the sc down the road
9t4lt4z28
Oct 2, 2015 10:28 AM
Hal Fisher
Sep 30, 2015 09:03 PM
HAWG
Sep 25, 2015 11:41 AM
