Keyless remote trunk issue
Old Oct 3, 2007 | 11:11 AM
lovemyblackz28's Avatar
Lately when I press the trunk button on the remote, the trunk will not open. I have to use the key to open the trunk. The doors lock and unlock just fine with the remote. When I press the trunk button on the remote, the only thing that happens is the interior light in the car goes on, thats bout it. Any ideas?
Old Oct 3, 2007 | 11:27 AM
Capn Pete's Avatar
Does the power hatch button inside the car work the hatch still? If not, then it's a problem with the power release. If that works though, then maybe it's a problem simply with your key-fob??
Old Oct 3, 2007 | 01:38 PM
Yes, the power button in the car works.
Old Oct 3, 2007 | 03:34 PM
Lunch Box's Avatar
Have you tried changing the battery or cleaning the contacts in the key fob?
Old Oct 18, 2007 | 09:18 AM
So I cleaned the contacts in the remote and I still have the same issue. I tried the second remote that came with the car and the exact same thing happens:
The lock and unlock works just fine but when presseing the trunk button on the remote, all that happens is the light in th ecar goes on. What does this mean? I figured maybe the remote is bad but its weird that it should be happening with both remotes (original from the factory). Do I order a new remote? Anyone ever use http://www.keylessrides.com ?
Old Oct 18, 2007 | 10:41 AM
TobyZ28's Avatar
Check the trunk release mechanism. It gets gummed up and sticky over the years. clean and relube it.
Old Oct 18, 2007 | 11:12 AM
But when I press the trunk button in the glove box, the trunk open just fine.
Old Oct 19, 2007 | 08:13 AM
01Z's Avatar
01Z
This happens to my 95 from time to time. I have removed my passenger side kick panel and moved the connector around. That seems to cause the trunk release to begin working again. One day I hope to de-oxit the connector and maybe make the fix more permanent.
gelbza
May 29, 2015 05:50 PM
warmeck
Mar 24, 2015 10:52 PM
Rod Bender
Jan 3, 2015 03:15 PM
Jeff1904
Jan 3, 2015 12:00 AM
squarehead
Nov 21, 2014 08:02 PM
