Keyless entry parts question
Old Aug 17, 2004 | 02:22 PM
KITT3000's Avatar
Question Keyless entry parts question
I would like to upgrade a 97 Firebird w/ power everything to having the factory keyless entry. I have come across another 97 Firebird that has the factory keyless entry and is wrecked. Which parts do I need from the wrecked bird for the keyless entry system? Thanks in advance for your help.
Old Aug 17, 2004 | 04:07 PM
Re: Keyless entry parts question
Besides the key fobs, just the Body Contol Module (BCM) from the car with the keyless entry. That's my best guess.
Old Aug 17, 2004 | 09:16 PM
RE AND CHERYL's Avatar
In most cases the BCM already has keyless entry. My 94 never came with keyless entry, but I performed the procedure for programing a new key fob and it worked. Now I have keyless entry.
I would just get a Keyfob and follow the procedures for programing in a new one. I beleive it's in the owners manual, if not I'm sure someone can help you out there.
Old Aug 17, 2004 | 09:26 PM
I knew shoebox would have it. Go HERE !
Old Aug 18, 2004 | 12:24 AM
There is a split in the way these things work between 1995 and earlier and 1996 and later. 1995 and earlier used a keyless entry receiver and had no BCM. The BCM was only introduced in 1996 and has the keyless function built into it. No separate receiver as before.
I guess it would be worth a shot to see if the programming worked without first swapping in a different BCM. I do know there are different BCMs based on how the car was optioned from the factory, though.
Old Aug 18, 2004 | 11:33 AM
KITT3000's Avatar
Question Re: Keyless entry parts question
Switched out the BCM with the other one. Keyless entry worked and all. Went to start the car and .....nothing happens. The security light is lit on the guage cluster. Stays lit after I take the key out. Any ideas?
oldschool
Feb 9, 2016 09:21 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
DirtyDan
Sep 28, 2009 10:27 AM
z28projects4ever
9
Jul 16, 2002 07:48 PM
