Key fob won't work. Think battery is dead. What to do?
Old Aug 28, 2004 | 12:46 PM
Brundle's Avatar
Just wondering if anyone knows how to replace a battery in one of the keyless entry remotes?
Just bought my 95 Z coupla weeks ago and both remotes r kinda weak (have to be real close to the car for it to work: pretty much right beside the car), and now one has stopped working all together.
I know there has got to be a way around this without replacing the whole thing, but i can't figure out how to open it up. Any help is appreciated.
Ryan
Old Aug 28, 2004 | 01:51 PM
Re: Key fob won't work. Think battery is dead. What to do?
Have an owner's manual?
Battery Replacement
Under normal use, the batteries in your key chain
transmitter should last about two years.
You can tell the batteries are weak if the transmitter
won’t work at the normal range in any location. If you
have to get close to your vehicle before the transmitter
works, it’s probably time to change the batteries.
Use two batteries, type DL20 16, or a similar type.
To replace batteries in the Remote Lock Control:
1. Carefully pry off the cover by inserting a dime (or similar object) in a slot between the covers and twist.
2. Lift off the front cover, bottom half first.
3. Remove and replace the batteries. Put new batteries
in printed side down.
4. Replace the front cover. Make sure the cover is on
tightly so water won’t get in.
5. Check the transmitter operation.
Old Aug 28, 2004 | 02:13 PM
Brundle's Avatar
Awesome, thanks a lot shoebox, work like a charm. Once again, u saved the day.
Feel kinda stupid now that it was so easy, but i tried getting it apart b4 and was worried i might bread the casing.
Thanks again,
Ryan
Old Aug 28, 2004 | 02:14 PM
Brundle's Avatar
Oh, and btw, no I didnt get the owners manual with the car, oddly enough.
Old Aug 28, 2004 | 02:19 PM
doodad's Avatar
I have had mine "lose its mind" before too. Wouldn't work at all. You have to point it at the OBD interface and hold the lock and unlock until the car beeps and the lights flash. Good as new again.
Old Aug 28, 2004 | 02:50 PM
You can get a pdf version from my Tech Page.
liamcg97
Nov 25, 2019 05:55 PM
Heathen1
Jan 2, 2016 04:27 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
Chris Ja
Aug 19, 2002 02:34 PM
RichardZ SS
Aug 3, 2002 12:26 PM
