Installing E-Cutout.. need power source.
Old Jul 30, 2004 | 05:46 PM
Kris93/95Z28's Avatar
Like the title says, where did you guys draw the power source from?
Thanks!
Old Jul 30, 2004 | 05:59 PM
Re: Installing E-Cutout.. need power source.
Oops. This is on an 02 Camaro
Old Jul 30, 2004 | 06:23 PM
2001NBMZ28's Avatar
I extended the power wire, ran it behind the driver's side carpet (just pulled it back), then to the 15 AMP radio fuse.
Old Jul 30, 2004 | 06:54 PM
I think I found where I am going to run it...
I ran my test light on the 2 hole from the left bottom of the fuse box.
It is a power source that is only hot with the key on
(I thought there might be one of those from the install on the last car I had a 93 Z28...)
Old Jul 31, 2004 | 10:04 AM
rncotton's Avatar
If I recall correectly, I tapped power from the cig. lighter.
Old Jul 31, 2004 | 11:31 AM
slayer6x6's Avatar
I like to use the power terminals at the fuse box. There are usually some terminals there with out any fuses.
Old Jul 31, 2004 | 03:11 PM
Okay the fuse box thing didn't work... It would blow the 10 AMP Fuse to the Guages
That scared the shiat out of me first time that happened....
The power source I did end up using was the Power Wire for the traction control.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jan 23, 2015 01:13 PM
