Installation instructions for overflow/battery tray
Old Jan 12, 2008 | 02:41 PM
mrmint69's Avatar
I ordered one for $25 through my dealership and will have it on Tuesday. I replaced my battery last week and saw the tube from the radiator running right under it so is there anything i should know or is it straight forward?
Old Jan 12, 2008 | 03:17 PM
n2ceptor's Avatar
Its straight forward....Just slowly remove the hose from the bottom....
Old Jan 19, 2008 | 05:42 PM
mrmint69's Avatar
In case anyone needs to do this in the future. The gasket in the top of the overflow is hard to remove so i cut the tank in half and pushed it out from the inside. The clamp hold down won't thread down so the new one must be thicker so i will need a longer bolt. My battery was also extremely tight and i had to jam it in to get it to fit. The liquid in the coolant tank was extremely dirty and looked like it came from a mud puddle so i am glad i did this.
Old Jan 19, 2008 | 05:51 PM
I had to do some slight modification to the little hold down block, IIRC.
Old Jan 22, 2008 | 12:01 PM
davidf4925's Avatar
its a pretty easy job, shouldn't take to long to do. I took mine out in probly 10min. good luck
Nov 18, 2023 07:21 PM
Richardan15
May 30, 2015 08:36 AM
Rde Bandit
Mar 21, 2015 10:17 PM
adam85
Parts Wanted
Jan 1, 2015 02:24 PM
ddr698
Dec 31, 2014 09:16 AM
