ignition swtich
Old Jan 9, 2007 | 10:14 PM
Daniel6718's Avatar
ignition swtich
ok car kept dying so i replaced, its been good for abour 3 weeks and its doing it again...but i think its the connector this time....
i was going to say i didnt want to cut and splice but i just read shoebox's site and it said you can knock the pins out and replace i nthe new connector!
does anybody know the price on it?
also does anybody else have the problem with their cruise controal not working all the time? it only works on occasion and theres nothing i change at all...sometimes i have to try 10 times before it will work and sometimes it wont work at all!
Old Jan 10, 2007 | 05:38 AM
Guest47904's Avatar
Guest
Cruise control won't work when the third brake light is out. Maybe it has a bad contact making it intermittent?
However ABS goes out too so not sure about that being the cause. It is easy to check however
Old Jan 10, 2007 | 11:23 AM
Daniel6718's Avatar
no...all the lights work...the abs light hasnt come on....i was thinking a bad ground somewhere but i dont know where it grounds...could be the switch? or do they just go bad and not work anymore?
Old Jan 14, 2007 | 08:56 AM
Guest47904's Avatar
Guest
For what it's worth, the cruise control module ground is located on the front left frame rail below the ABS unit and behind the air pump.
Old Jan 14, 2007 | 02:54 PM
tiafn2's Avatar
I got the connectors from gmpartsdirect.com. One was $14 and the other was $16.
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
PopoFormula
Oct 12, 2015 04:19 PM
tommalcolm
Sep 11, 2015 03:39 PM
Aaront810
Sep 11, 2015 11:24 AM
